Thursday,09,May,2019,13:04:01:53651
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.3.0
Data version: 20170203 DS267.2
www.Ross-Tech.com
Address 01: Engine (03C 906 021 A)
13:03:44 Group 001: General
680 /min Engine Speed (G28)
67.0°C Coolant Temperature (G62)
0.0 % Lambda Control Bank 1
10110110 Basic Setting Requirements
13:04:10 Group 001: General
13:04:10 Group 002: General
23.3 % Engine Load
1.02 ms Injection Timing
390.0 mbar Intake Manifold Pressure (G71)
13:04:10 Group 003: General
640 /min Engine Speed (G28)
2.0 % Throttle Valve Angle
16.5 °BTDC Ignition Timing Angle
13:04:34 Group 010: Ignition
19.5 % Engine Load
1.2 % Throttle Valve Angle
6.0 °BTDC Ignition Timing Angle
13:04:34 Group 014: Ignition (Misfire Recognition - Total)
19.5 % Engine Load
0 Misfire Counter
Enabled Misfire Recognition
13:04:34 Group 015: Ignition (Misfire Recognition - Cylinder 1-3)
0 Misfire Counter Cylinder 1
0 Misfire Counter Cylinder 2
0 Misfire Counter Cylinder 3
13:05:09 Group 022: Ignition (Timing Retardation Cylinder 1 && 2)
19.5 % Engine Load
0.0°KW Timing Retardation Cylinder 1
0.0°KW Timing Retardation Cylinder 2
13:05:09 Group 028: Ignition (Knock Sensor Test)
19.5 % Engine Load
69.0°C Coolant Temperature (G62)
Test OFF Knock Sensor Test Result
13:05:09 Group 026: Ignition (Knock Control Cylinder 1-4)
0.624 V Knock Sensor Voltage Cylinder 1
0.468 V Knock Sensor Voltage Cylinder 2
0.624 V Knock Sensor Voltage Cylinder 3
0.624 V Knock Sensor Voltage Cylinder 4
13:05:22 Group 031: Lambda Control (Lambda Sensor Voltages)
0.97 Lambda Control Bank 1 (actual)
1.00 Lambda Control Bank 1 (specified)
13:05:22 Group 032: Lambda Control (Mixture Adaptation)
0.6 % Adaptation (Idle) Bank 1 Sensor 1
6.6 % Adaptation (Partial) Bank 1 Sensor 1
13:05:22 Group 026: Ignition (Knock Control Cylinder 1-4)
13:05:52 Group 041: Lambda Control (Lambda Sensor Heating Bank 1)
299 ohms Resistance Bank 1 Sensor 1
Htg. S1 ON Heater Condition Bank 1 Sensor 1
Resistance Bank 1 Sensor 2
Htg. S2 OFF Heater Condition Bank 1 Sensor 2
13:05:52 Group 035
13:05:52 Group 038
13:05:58 Group 043: Lambda Control (Aging Check: Bank 1 Sensor 2)
192.0°C Catalytic Converter Bank 1 Temp.
0.45 V Lambda Voltage Bank 1 Sensor 1
Test OFF Lambda Sensor Aging Test B1S2
13:05:58 Group 035
13:05:58 Group 038
13:06:07 Group 046: Lambda Control (Catalytic Conversion Test Bank 1)
276.0°C Catalytic Converter Bank 1 Temp.
2.50 Catalytic Conversion Bank 1
Test OFF Cat. Conversion Test Bank 1
13:06:35 Group 060: Electronic Throttle (Throttle Body Alignment)
10.9 % Throttle Valve Sensor 1 (G187)
88.7 % Throttle Valve Sensor 2 (G188)
4 Throttle Valve Steps Counter
ADP. O.K. Throttle Body Alignment Status
13:06:48 Group 062: Electronic Throttle (Sensor Values)
14.5 % Accel. Pedal Pos. Sensor 1 (G79)
7.4 % Accel. Pedal Pos. Sensor 2 (G185)
13:06:56 Group 064: Electronic Throttle (Sensor Adaption Values)
0.500 V Lower Adaptation Sensor 1 (G187)
4.600 V Lower Adaptation Sensor 2 (G188)
0.760 V Emergency Air Gap Sensor 1 (G187)
4.340 V Emergency Air Gap Sensor 2 (G188)
13:07:13 Group 070: Emission Reduction (EVAP Valve Test)
48.0 % Evap. Emissions Sol. Valve (Open)
-1.6 % Lambda Control
0.0 % Evap. Emissions Sol. Valve (Flow)
Test OFF EVAP Valve Test
13:07:38 Group 090: Camshaft Adjustment (Intake)
Cam Ctrl. ON Cam. Adjustment Intake Status
20.5°KW Cam. Adjustment Intake B1 (act.)
13:07:45 Group 091: Camshaft Adjustment (Bank 1 Intake)
5.9 % Cam. Adjustment Intake Bank 1
21.0°KW Cam. Adjustment Intake B1 (spec.)
13:07:53 Group 093: Camshaft Adjustment Adaptation
110.86° Phase Position Bank 1 Intake
13:08:06 Group 100: Readiness Code
01100001 Readiness Bits
76.0°C Coolant Temperature (G62)
332.8 s Time since Engine Start
01000001 OBD-Status
13:08:14 Group 101: Fuel Injection
19.5 % Engine Load
340.0 mbar Intake Manifold Pressure (G71)
13:08:21 Group 102: Fuel Injection
20.0°C Intake Air Temperature (G42)
13:08:29 Group 105: Fuel Injection (Cylinder Shut-Off)
19.5 % Engine Load
77.0°C Coolant Temperature (G62)
OFF Status Cylinder Shut-Off
13:08:34 Group 106: Fuel Injection (Fuel Supply System)
49.75 bar Fuel Rail Pressure (actual)
ON Electric Fuel Pump
49.00 s Fuel Pump Shut-Off Time
13:08:36 Group 106: Fuel Injection (Fuel Supply System)
50.06 bar Fuel Rail Pressure (actual)
13:08:50 Group 108
0.0 /s Misfires
0 Count
00000000 Bin. Bits
00000000 Bin. Bits
13:09:05 Group 112: Exhaust Gas Temperature
205°C Exhaust Gas Temperature Bank 1
13:09:14 Group 114: Charge Pressure Control
19.4 % Engine Load (specified)
19.5 % Engine Load (actual Value)
5.1 % Boost Pressure Control (N75)
13:09:34 Group 120: Traction Control (ASR)
359.0 Nm Torque specified by ASR
1.8 Nm Engine Torque (actual)
ASR OFF Traction Control Status
13:09:52 Group 129: CAN-Databus Communication (Powertrain)
Instruments 1 Oil Temp./Level Sensor (G266)
Gateway 1 CAN-Gateway (J533)
Park Brake 1 Parking Brake (J540)
13:09:57 Group 130: Engine Cooling (Map Cooling)
80.0°C Engine Outlet Temperature
13.0°C Radiator Outlet Temperature
OFF Map Cooling System Test
13:10:03 Group 131: Engine Cooling (Map Cooling)
80.0°C Engine Outlet Temperature (act.)
95.0°C Engine Outlet Temperature (spec.)
13:10:09 Group 132: Engine Cooling (Map Cooling)
15.0°C Temp. Difference Radiator/Engine
00000101 Cooling Status
13:10:16 Group 134: Engine Cooling (Temperatures)
66.0°C Oil Temperature
13.5°C Ambient Temperature
21.0°C Intake Air Temperature (G42)
13:10:30 Group 140: Fuel Supply System (Quantity Control Valve)
49.6° Quantity Valve closing Angle
50.00 bar Fuel Rail Pressure (spec.)
50.11 bar Fuel Rail Pressure (actual)
01 Quantity Control Valve Status
13:10:38 Group 141: Fuel Supply System (Quantity Control Valve)
-0.19 bar High Pressure System Adaptation
-0.61 bar Controller Portion
-0.45 bar Total Compression Volume
3 Fuel Rail Pressure (actual)
13:10:49 Group 141: Fuel Supply System (Quantity Control Valve)
-0.14 bar High Pressure System Adaptation
0.07 bar Total Compression Volume
13:11:18 Group 166: Lambda Control (Lambda Sensor Plausibility)
0.99 Lambda Control Bank 1 (actual)
0.45 V Sensor Voltage Bank 1 Sensor 1
1.09 Integral Mass Air Flow
Test OFF Plausibility Test B1-S1
13:11:25 Group 168: Turbo Charger Bypass Flap
98.8 % Load
99.6 % Load
-8.6 % Lambda
Test OFF
13:11:25 Group 035
13:11:25 Group 038
13:12:01 Group 201
Htg. S2 OFF
342.0°C Temperature
ADP. Run
13:12:01 Group 035
13:12:01 Group 038
13:12:09 Group 203
0.0 % Lambda
1.8 % Lambda
00000000 Bin. Bits
00001000 Bin. Bits
13:12:27 Group 203
0.0 % Lambda
1.8 % Lambda
00000000 Bin. Bits
00001000 Bin. Bits
13:12:27 Group 033: Lambda Control
0.4 % Lambda Control Bank 1 Sensor 1
1.46 V Sensor Voltage Bank 1 Sensor 1
13:12:27 Group 031: Lambda Control (Lambda Sensor Voltages)
0.98 Lambda Control Bank 1 (actual)
13:12:43 Group 204
680 /min RPM
37.5 % Load
780.0°C Temperature
00000000 Bin. Bits
13:12:48 Group 205
11.47 kOhm Resistance
00000000 Bin. Bits
13:13:15 Group 215
0.0°KW Idle Stabilization
21.0°KW Idle Stabilization
20.5°KW Idle Stabilization
10000100 Bin. Bits
13:13:15 Group 035
13:13:15 Group 035
13:13:41 Group 224
-0.8°KW Idle Stabilization
-3.0°KW Idle Stabilization
13:13:41 Group 035
13:13:41 Group 035
13:13:50 Group 226
990.0 mbar Absolute Pres.
330.0 mbar Pressure
180.0 mbar Absolute Pres.
920.0 mbar Absolute Pres.
13:14:16 Group 236
99.6 % Load
5.1 % Load
360.0 mbar Absolute Pres.
980.0 mbar Absolute Pres.
13:14:24 Group 239
23.0°C Temperature
22.0°C Temperature
24.0°C Temperature
13.5°C Temperature
13:14:24 Group 035
