Tuesday,15,May,2012,18:43:15:56834,VCDS Version: Release 11.11.2,Data version: 20120126
03G 906 021 LR,,R4 1.9L EDC G000SG 9248,
,Group A:,'003,,,,Group B:,'010,,,,Group C:,'011
,,Engine Speed,Exhaust Gas,Exhaust Gas,Exhaust Gas,,Mass Air Flow,Atmospheric,Boost Pressure,Accel. Pedal Pos.,,Engine Speed,Boost Pressure,Boost Pressure,Charge Pressure
,TIME,(G28),Recirculat. (spec.),Recirculat. (actual),Recirc. Duty Cycle,TIME,(actual),Pressure,(actual),Sensor 1 (G79),TIME,(G28),(specified),(actual),Control Duty Cycle
Marker,STAMP, /min, mg/str, mg/str, %,STAMP, mg/str, mbar, mbar, %,STAMP, /min, mbar, mbar, %
,0.00,1155,540.0,520.0,65.1,0.16,530.0,979.2,1162. 8,44.7,0.36,1197,1499.4,1183.2,84.8
,0.52,1218,610.0,565.0,95.5,0.68,565.0,979.2,1234. 2,61.2,0.87,1281,1560.6,1264.8,85.2
,1.03,1302,655.0,590.0,95.5,1.19,590.0,979.2,1326. 0,67.1,1.40,1365,1642.2,1366.8,81.7
,1.57,1407,700.0,620.0,95.5,1.74,640.0,979.2,1448. 4,86.3,1.94,1470,1734.0,1509.6,74.2
,2.11,1512,725.0,720.0,95.5,2.28,760.0,979.2,1632. 0,98.0,2.48,1596,1805.4,1713.6,69.4
,2.65,1638,755.0,820.0,95.5,2.82,840.0,979.2,1846. 2,100.0,3.02,1722,1887.0,1917.6,59.6
,3.19,1764,775.0,905.0,95.5,3.36,910.0,979.2,2040. 0,100.0,3.56,1848,1968.6,2111.4,46.9
,3.74,1911,790.0,960.0,95.5,3.91,975.0,979.2,2223. 6,100.0,4.12,2016,2029.8,2284.8,39.1
,4.29,2058,805.0,995.0,95.5,4.46,1000.0,979.2,2335 .8,100.0,4.65,2163,2040.0,2346.0,32.7
,4.82,2205,815.0,980.0,95.5,4.98,980.0,979.2,2346. 0,100.0,5.18,2289,2040.0,2335.8,26.8
,5.34,2331,825.0,990.0,95.5,5.50,990.0,979.2,2335. 8,100.0,5.70,2415,2040.0,2346.0,20.5
,5.86,2457,830.0,990.0,95.5,6.02,985.0,979.2,2356. 2,100.0,6.23,2562,2040.0,2376.6,15.0
,6.40,2604,835.0,990.0,95.5,6.57,995.0,979.2,2397. 0,100.0,6.78,2688,2040.0,2407.2,15.0
,6.95,2730,840.0,1005.0,95.5,7.12,1000.0,979.2,242 7.6,100.0,7.32,2814,2040.0,2427.6,15.0
,7.49,2856,840.0,1005.0,95.5,7.66,1010.0,979.2,242 7.6,100.0,7.86,2940,2040.0,2427.6,15.0
,8.03,2982,850.0,1000.0,95.5,8.20,1000.0,979.2,241 7.4,100.0,8.40,3066,2040.0,2417.4,15.0
,8.57,3108,850.0,990.0,95.5,8.74,980.0,979.2,2397. 0,100.0,8.94,3192,2040.0,2386.8,15.8
,9.11,3234,850.0,965.0,95.5,9.27,960.0,979.2,2366. 4,100.0,9.47,3297,2040.0,2356.2,15.4
,9.63,3339,850.0,955.0,95.5,9.79,955.0,979.2,2325. 6,100.0,9.99,3402,2040.0,2305.2,16.2
,10.15,3423,850.0,935.0,95.5,10.31,925.0,979.2,228 4.8,100.0,10.51,3507,2040.0,2274.6,15.4
,10.68,3528,850.0,915.0,95.5,10.84,920.0,979.2,224 4.0,26.7,11.04,3465,1193.4,2142.0,50.1
,11.21,3528,505.0,615.0,95.5,11.38,540.0,979.2,170 3.4,0.0,11.58,3465,1193.4,1530.0,50.1
,11.75,3465,505.0,480.0,95.5,11.92,460.0,979.2,133 6.2,0.0,12.12,3423,1193.4,1275.0,52.5
,12.29,3402,500.0,440.0,95.5,12.46,430.0,979.2,119 3.4,0.0,12.66,3360,1193.4,1162.8,53.7
,12.83,3339,490.0,420.0,95.5,13.00,415.0,979.2,113 2.2,0.0,13.20,3318,1183.2,1122.0,55.6
,13.37,3297,480.0,415.0,95.5,13.54,415.0,979.2,110 1.6,0.0,13.74,3255,1183.2,1101.6,57.6
,13.90,3234,470.0,410.0,95.5,14.06,415.0,979.2,109 1.4,0.0,14.26,3192,1183.2,1091.4,59.6
,14.42,3171,460.0,410.0,95.5,14.58,410.0,979.2,109 1.4,0.0,14.78,3150,1183.2,1091.4,61.2
,14.94,3129,450.0,420.0,95.5,15.10,405.0,979.2,109 1.4,0.0,15.30,3108,1183.2,1081.2,62.7
,15.46,3087,445.0,400.0,95.5,15.62,410.0,979.2,108 1.2,0.0,15.82,3066,1183.2,1081.2,63.9
,15.99,3045,435.0,405.0,95.5,16.16,405.0,979.2,108 1.2,0.0,16.36,3024,1183.2,1081.2,65.5
,16.53,3003,430.0,400.0,95.5,16.70,405.0,979.2,108 1.2,0.0,16.90,2982,1173.0,1081.2,65.9
,17.07,2961,420.0,400.0,95.5,17.24,390.0,979.2,108 1.2,0.0,17.44,2940,1173.0,1081.2,66.3
,17.62,2919,415.0,400.0,95.5,17.79,400.0,979.2,108 1.2,0.0,17.99,2877,1173.0,1091.4,66.7
,18.16,2877,410.0,395.0,95.5,18.33,400.0,979.2,109 1.4,0.0,18.53,2856,1173.0,1091.4,67.1
,18.70,2835,400.0,395.0,95.5,18.86,405.0,979.2,109 1.4,0.0,19.06,2814,1173.0,1091.4,67.1
это первый лог
и второй
Tuesday,15,May,2012,18:32:16:56834,VCDS Version: Release 11.11.2,Data version: 20120126
,0.38,1365,220.0,490.0,28.4,0.00,565.0,979.2,1254. 6,44.3,0.19,1365,1285.2,1295.4,79.7
,0.95,1386,220.0,230.0,28.8,0.57,245.0,979.2,1315. 8,9.0,0.76,1365,1091.4,1224.0,78.1
,1.52,1365,330.0,215.0,95.5,1.14,195.0,979.2,1122. 0,9.4,1.33,1365,1091.4,1091.4,78.1
,2.09,1323,330.0,405.0,95.5,1.71,405.0,979.2,1040. 4,0.0,1.90,1344,1091.4,1040.4,78.1
,2.66,1281,330.0,425.0,95.5,2.28,410.0,979.2,1050. 6,0.0,2.47,1302,1091.4,1060.8,78.9
,3.23,1302,620.0,420.0,95.5,2.85,420.0,979.2,1060. 8,0.0,3.04,1281,1091.4,1060.8,79.3
,3.81,1344,665.0,515.0,95.5,3.42,480.0,979.2,1071. 0,93.3,3.62,1323,1509.6,1111.8,90.3
,4.39,1428,705.0,570.0,95.5,4.01,530.0,979.2,1193. 4,100.0,4.20,1386,1642.2,1234.2,89.6
,4.97,1533,730.0,645.0,95.5,4.58,605.0,979.2,1336. 2,100.0,4.77,1491,1734.0,1387.2,81.7
,5.54,1659,755.0,765.0,95.5,5.16,680.0,979.2,1519. 8,100.0,5.35,1617,1815.6,1581.0,71.4
,6.11,1806,780.0,880.0,95.5,5.73,795.0,979.2,1744. 2,100.0,5.92,1764,1897.2,1836.0,65.5
,6.68,1953,795.0,920.0,95.5,6.30,900.0,979.2,2009. 4,100.0,6.49,1911,1989.0,2080.8,50.5
,7.26,2100,810.0,985.0,95.5,6.87,960.0,979.2,2223. 6,100.0,7.07,2058,2040.0,2274.6,41.0
,7.83,2247,820.0,1015.0,95.5,7.45,995.0,979.2,2366 .4,100.0,7.64,2205,2040.0,2397.0,30.4
,8.39,2394,825.0,975.0,95.5,8.02,965.0,979.2,2417. 4,100.0,8.20,2352,2040.0,2386.8,26.8
,8.97,2541,835.0,995.0,95.5,8.58,980.0,979.2,2366. 4,100.0,8.77,2499,2040.0,2376.6,17.4
,9.54,2688,835.0,1000.0,95.5,9.16,995.0,979.2,2417 .4,100.0,9.35,2646,2040.0,2427.6,15.0
,10.13,2814,840.0,1000.0,95.5,9.73,995.0,979.2,244 8.0,100.0,9.93,2772,2040.0,2458.2,15.0
,10.71,2940,850.0,1015.0,95.5,10.32,1005.0,979.2,2 468.4,100.0,10.52,2898,2040.0,2468.4,15.0
,11.28,3066,850.0,1005.0,95.5,10.90,1010.0,979.2,2 468.4,100.0,11.09,3024,2040.0,2468.4,15.0
,11.86,3171,850.0,985.0,95.5,11.47,1000.0,979.2,24 58.2,100.0,11.66,3150,2040.0,2448.0,15.0
,12.44,3297,850.0,980.0,95.5,12.06,985.0,979.2,243 7.8,100.0,12.25,3255,2040.0,2427.6,15.4
,13.01,3381,850.0,955.0,95.5,12.63,975.0,979.2,240 7.2,100.0,12.82,3360,2040.0,2397.0,15.8
,13.58,3381,495.0,895.0,95.5,13.20,950.0,979.2,236 6.4,92.2,13.39,3444,1479.0,2356.2,6.7
,14.17,3381,495.0,540.0,95.5,13.78,705.0,979.2,212 1.6,0.0,13.98,3402,1193.4,1856.4,53.7
,14.74,3297,480.0,460.0,95.5,14.36,510.0,979.2,151 9.8,0.0,14.55,3318,1183.2,1407.6,56.0
,15.31,3213,465.0,445.0,95.5,14.93,455.0,979.2,128 5.2,0.0,15.12,3255,1183.2,1254.6,58.4
,15.88,3150,455.0,435.0,95.5,15.50,440.0,979.2,120 3.6,0.0,15.69,3171,1183.2,1183.2,61.2
,16.45,3087,445.0,425.0,95.5,16.07,435.0,979.2,117 3.0,0.0,16.26,3087,1183.2,1162.8,63.5
,17.02,3024,430.0,425.0,95.5,16.64,430.0,979.2,116 2.8,0.0,16.83,3024,1183.2,1152.6,65.9
,17.60,2940,415.0,415.0,95.5,17.21,430.0,979.2,115 2.6,0.0,17.40,2961,1173.0,1152.6,67.1
,18.17,2856,405.0,410.0,95.5,17.79,430.0,979.2,115 2.6,0.0,17.98,2898,1173.0,1152.6,67.5
,18.75,2793,395.0,415.0,95.5,18.36,405.0,979.2,114 2.4,0.0,18.55,2835,1173.0,1142.4,67.9
,19.33,2730,395.0,400.0,95.5,18.95,405.0,979.2,114 2.4,0.0,19.14,2751,1173.0,1132.2,68.3
,19.90,2667,390.0,415.0,95.5,19.52,420.0,979.2,113 2.2,0.0,19.71,2688,1162.8,1132.2,68.6
,20.47,2604,385.0,420.0,95.5,20.09,410.0,979.2,112 2.0,0.0,20.28,2625,1162.8,1122.0,69.0
,21.05,2541,385.0,425.0,95.5,20.67,430.0,979.2,112 2.0,0.0,20.86,2562,1162.8,1122.0,69.4
,21.61,2478,375.0,425.0,95.5,21.23,420.0,979.2,112 2.0,0.0,21.42,2499,1152.6,1122.0,69.8
,22.18,2415,360.0,430.0,95.5,21.80,430.0,979.2,111 1.8,0.0,21.99,2436,1152.6,1111.8,69.8
,22.76,2352,350.0,430.0,95.5,22.37,435.0,979.2,111 1.8,0.0,22.57,2373,1152.6,1101.6,69.4
,23.33,2289,335.0,435.0,95.5,22.95,435.0,979.2,110 1.6,0.0,23.14,2310,1152.6,1101.6,69.4
,23.91,2226,330.0,430.0,95.5,23.53,430.0,979.2,110 1.6,0.0,23.72,2247,1152.6,1101.6,69.4
,24.50,2163,330.0,430.0,95.5,24.10,430.0,979.2,109 1.4,0.0,24.29,2205,1142.4,1091.4,69.4
,25.07,2121,330.0,420.0,95.5,24.69,420.0,979.2,109 1.4,0.0,24.88,2142,1132.2,1091.4,69.4
,25.65,2058,330.0,425.0,95.5,25.26,420.0,979.2,108 1.2,0.0,25.45,2079,1122.0,1081.2,69.4
,26.22,2016,330.0,425.0,95.5,25.84,420.0,979.2,108 1.2,0.0,26.03,2037,1122.0,1081.2,69.0
,26.79,1953,330.0,425.0,95.5,26.41,420.0,979.2,108 1.2,0.0,26.60,1974,1111.8,1081.2,69.8
,27.36,1911,330.0,425.0,95.5,26.98,430.0,979.2,108 1.2,0.0,27.17,1932,1101.6,1081.2,70.6
,27.94,1869,330.0,430.0,95.5,27.56,425.0,979.2,107 1.0,0.0,27.75,1869,1101.6,1071.0,71.4
,28.51,1806,330.0,430.0,95.5,28.13,425.0,979.2,107 1.0,0.0,28.32,1827,1101.6,1071.0,71.4
,29.08,1764,330.0,430.0,95.5,28.70,430.0,979.2,107 1.0,0.0,28.89,1785,1091.4,1060.8,71.8
,29.66,1701,330.0,430.0,95.5,29.27,430.0,979.2,106 0.8,0.0,29.47,1722,1091.4,1060.8,72.2
,30.22,1659,330.0,425.0,95.5,29.85,425.0,979.2,106 0.8,0.0,30.04,1680,1091.4,1060.8,72.6
,30.79,1617,330.0,415.0,95.5,30.41,420.0,979.2,105 0.6,0.0,30.60,1638,1091.4,1050.6,73.0
