Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 3C0 907 115 S HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWZCZ000000000
Coding: 0404010A19070160
Shop #: WSC 08258 444 57911
VCID: 3064129E9C79459C
2 Faults Found
000256 - Mass Air Flow Sensor (G70): Supply Voltage
P0100 - 004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Mileage: 70928 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 81.0°C
Temperature: 58.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.446 V
001110 - EVAP System: Very Small Leak Detected
P0456 - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Mileage: 70934 km
Time Indication: 0
Date: 2011.09.13
Time: 11:48:22
Freeze Frame:
RPM: 1229 /min
Load: 28.2 %
Speed: 5.0 km/h
Temperature: 84.0°C
Temperature: 27.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09G-927-750.lbl
Part No SW: 09G 927 750 HJ HW: 09G 927 750 HJ
Component: AQ 250 6F 1068
Revision: 00H69000 Serial number:
Coding: 0000584
Shop #: WSC 00028 028 00001
VCID: 8004025EEC59951C
1 Fault Found
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 2
Reset counter: 134
Mileage: 0 km
Time Indication: 0
Address 03: ABS Brakes Labels: 3C0-614-109-C4.lbl
Part No SW: 3C0 614 109 D HW: 3C0 614 109 D
Component: J104 C4 440 V2 0003
Revision: --020--- Serial number: 00000775731046
Coding: 0000348
VCID: 1F46E122F1E7CAE4
1 Fault Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 34
Mileage: 70928 km
Time Indication: 0
Date: 2011.09.12
Time: 18:41:24
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 12.00 V
Bin. Bits: 00011111
Count: 217
