hassis Type: 3C0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ7P049043 Mileage: 229790km/142784miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 07010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 06F 997 058 R HW: 06F 906 056 EK
Component: MED9.5.10 G00 2104
Revision: 69H03--- Serial number: VWZCZ000000000
Coding: 0000075
Shop #: WSC 00112 935 59685
VCID: 4487AA9B0780FE3
4 Faults Found:
001056 - Catalyst System; Bank 1
P0420 - 002 - Efficiency Below Threshold
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 2
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 2400 /min
Load: 52.9 %
Speed: 98.0 km/h
Temperature: 79.0°C
000105 - Intake Manifold Pressure <-> Ambient Air Pressure
P0069 - 008 - Incorrect Correlation - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 30
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 10200 /min
Load: 100.0 %
Speed: 255.0 km/h
Temperature: 215.0°C
000819 - Knock Sensor 2 (G66)
P0333 - 001 - Signal too High - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 10200 /min
Load: 100.0 %
Speed: 255.0 km/h
005715 - Please check DTC Memory of ABS Controller
P1653 - 004 -
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 7
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 240 /min
Load: 85.5 %
Speed: 0.0 km/h
Temperature: 25.0°C
Readiness: 1000 0001
Address 02: Auto Trans Labels: 09G-927-750.lbl
Part No SW: 09G 927 750 S HW: 09G 927 750 S
Component: AQ 250 6F 0746
Revision: 00H38000 Serial number:
Coding: 0000072
Shop #: WSC 00028 028 00001
VCID: 4189A38F1892EBB
No fault code found.
Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0667855772
Coding: 0046481
VCID: 326BFC43AD34403
6 Faults Found:
01542 - Yaw Rate Sensor (G202)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 254
Reset counter: 208
Mileage: 210206 km
Time Indication: 0
Date: 2000.00.00
Time: 14:10:33
01423 - Lateral Acceleration Sensor (G200)
014 - Defective
Freeze Frame:
Fault Priority: 3
Reset counter: 208
Mileage: 210206 km
Time Indication: 0
Date: 2000.00.00
Time: 14:10:33
01279 - Longitudinal Acceleration Sensor (G251)
014 - Defective
Freeze Frame:
Fault Priority: 3
Reset counter: 208
Mileage: 210206 km
Time Indication: 0
Date: 2000.00.00
Time: 14:10:33
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Priority: 3
Reset counter: 208
Mileage: 210206 km
Time Indication: 0
Date: 2000.00.00
Time: 14:10:33
Freeze Frame:
Fault Priority: 3
Reset counter: 208
Mileage: 210206 km
Time Indication: 0
Date: 2000.00.00
Time: 14:10:33
Freeze Frame:
Fault Priority: 3
Reset counter: 208
Mileage: 210206 km
Time Indication: 0
Date: 2000.00.00
Time: 14:10:33
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AJ HW: 3C0 907 044 AJ
Component: ClimatronicPQ46 050 0505
Revision: 00050005 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 69D95B2F4062C3B
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 K HW: 3C0 937 049 K
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000004304592
Coding: 00848F0700041A00000A00000F000000000D59435C0000
VCID: 3169F34FA8327BB
Subsystem 1 - Part No: 3C1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 00028
2 Faults Found:
02071 - Local Databus
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 106
Mileage: 227754 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.20 V
OFF
OFF
OFF
OFF
OFF
00153 - Windshield Wiper Motor; Driver Side (V216)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 106
Mileage: 227754 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.20 V
OFF
OFF
OFF
OFF
OFF
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
Component: 03 AIRBAG VW8 031 2522
Revision: 11031000 Serial number: 003B1PKVSV2N
Coding: 0012339
Shop #: WSC 00112 935 16231
VCID: 306FF64BA338723
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 A HW: 3C0 953 549 A
Component: Lenksдulenmodul 006 0010
Revision: 00006000 Serial number: 3C5953507B
Coding: 0001011
VCID: 2A5BE42385E4083
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 851 S HW: 3C0 920 851 S
Component: KOMBIINSTRUMENT VD1 1614
Revision: X0006000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 00500 935 81021
Address 19: CAN Gateway Labels: 3C0-907-530.lbl
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C067180C43
Coding: 3FFD0C04C21002
VCID: 2149030FF8D2CBB
2 Faults Found:
01305 - Databus for Infotainment
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 35
Mileage: 210250 km
Time Indication: 0
Date: 2000.00.00
Time: 15:45:09
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 234
Reset counter: 134
Mileage: 210265 km
Time Indication: 0
Date: 2000.00.00
Time: 16:15:21
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 3979CB6F7042B3B
Part No: 3C0 905 861 F
Component: ELV 026 0380
3C0905861F ELV 026 0380
1 Fault Found:
01176 - Key
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 1
Fault Frequency: 3
Reset counter: 205
Mileage: 195833 km
Time Indication: 0
Date: 2000.00.00
Time: 19:23:04
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1123
Revision: 12006001 Serial number: 00000548068818
Coding: 0000181
VCID: 3B75D1677A7E81B
2 Faults Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 133
Mileage: 0 km
Time Indication: 0
00100 - Drivers Interior Locking Button (E308)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 107
Mileage: 228350 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.134 H07 1806
VCID: 3467FA5B57204E3
Address 46: Central Conv. Labels: None
VCID: 55A167DFBC1A77B
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1123
Revision: 12006001 Serial number: 00000547468818
Coding: 0000180
VCID: 3C77D27B7F70863
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000012
1 Fault Found:
01487 - System Function Test
008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 4
Reset counter: 94
Mileage: 225120 km
Time Indication: 0
Date: 2000.00.00
Time: 11:10:04
Freeze Frame:
Voltage: 11.18 V
Count: 100
Address 56: Radio (J503) Labels: None
Part No SW: 3AD 035 190 A HW: 3AD 035 190 A
Component: RCD510USBRVC 003 0003
Revision: -----001 Serial number: VWZ4Z3P8000801
Coding: 01000424040010
Shop #: WSC 00079 790 00000
VCID: 2B55E1274A1E11B
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 209
Mileage: 210206 km
Time Indication: 0
Date: 2000.00.00
Time: 13:55:39
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Reset counter: 93
Mileage: 212017 km
Time Indication: 0
Date: 2000.00.00
Time: 23:20:13
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1113
Revision: 11005001 Serial number: 00000000526349
Coding: 0000144
VCID: 3D71DF7F646A8FB
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1113
Revision: 11005001 Serial number: 00000000534389
Coding: 0000144
VCID: 3E73D873696C943
End ---------------------------------------------------------------------
Address 01: DTCs cleared
Address 02: DTCs cleared
