в бортовой сети какие ошибки ... их и читай
где найти ошибки в боротовой сети? скан показывает только эту ошибку.
полный скан ? кабель какой ?
кабель китайский 908-й.
вот полный скан:
Sunday,11,April,2010,14:35:59:13314
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 1K0
Scan: 01 02 03 08 09 10 15 16 17 19 1C 22 25 42 44 46 52 53 55 56
62 72
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CAW) Labels: Redir Fail!
Part No SW: 06J 906 026 AB HW: 06J 906 026 D
Component: MED17.5 4304
Revision: A7H18--- Serial number:
Coding: 04230003190F0160
Shop #: WSC 01530 935 00200
No fault code found.
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09G-927-750.lbl
Part No SW: 09G 927 750 FE HW: 09G 927 750 FE
Component: AQ 250 6F 1701
Revision: 00H90000 Serial number:
Coding: 0000328
Address 03: ABS Brakes Labels: None
Part No SW: 5N0 614 109 M HW: 5N0 614 109 M
Component: J104 C4 450 V229 0003
Revision: --H28--- Serial number: 00000002606352
Coding: 0011540
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01006
ROD: EV_Climatronic_VW36.rod
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 D HW: 5K0 937 087 D
Component: BCM PQ35 H 011 0028
Revision: BE011001
Coding: 48180A3BF825F3C040080080340009A443553088736D8D605C 8000000000
Part No SW: 5N1 955 119 HW:
Component: Wischer 26021 012 0203
Coding: 009795
Part No: 1K0 955 559 AH
Component: RLS 030310 05 54 0403
Coding: 03304D
Part No: 1K8 951 171
Component: DWA-Sensor 00 001 0104
Coding: 000000
Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 5N0 919 475 B HW: 5N0 919 475
Component: PARKHILFE 4K H07 0023
Revision: -------- Serial number: 11131002620737
Coding: 100102
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 J HW: 5N0 959 655 J
Component: J234__200 VW10 HI 1916
Revision: 20013000 Serial number: 003E2P2PL6Z4
Coding: 0012336
Shop #: WSC 04056 056 00200
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 056 0111
Coding: 0001132
Part No: XXXXXXXXXXX
Component: E0221 002 0030
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5N0 920 871 A HW: 5N0 920 871 A
Component: KOMBI H05 0305
Serial number: 00000000000000
Coding: 110F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AF HW: 1K0 907 951
Component: J533 Gateway H17 0233
Revision: H17 Serial number: 1521J10215044D
Coding: FDA37F06001202006002
Address 1C: Position Sensing Labels: None
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223T73HC04
Coding: 0000002
Address 22: AWD Labels: None
Part No SW: 0AY 907 554 C HW: 0AY 907 554 C
Component: Haldex 4Motion 0041
Coding: 0000005
Shop #: WSC 00000 000 00000
Address 25: Immobilizer (J334) Labels: None
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0305
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
Address 42: Door Elect, Driver Labels: None
Part No SW: 5N0 959 701 E HW: 5N0 959 701 E
Component: Tuer-SG 009 2101
Coding: 0004286
Address 44: Steering Assist Labels: 5Nx-909-144.lbl
Part No SW: 5N1 909 144 K HW: 5N1 909 148 G
Component: J500__APA-BS KL.163 0703
Revision: 1AH03828 Serial number: 00100470067701
Coding: 0000258
Address 52: Door Elect, Pass. Labels: None
Part No SW: 5N0 959 702 E HW: 5N0 959 702 E
Coding: 0004542
Address 53: Parking Brake Labels: None
Part No SW: 3AA 907 801 B HW: 3AA 907 801 B
Component: J540 EPB4 VW-49878 0004
Revision: H17 Serial number: 00000000002298
Coding: 0023057
1 Fault Found:
00457 - Control Module for Network (J519)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 81
Mileage: 723 km
Time Indication: 0
Date: 2001.14.13
Time: 14:31:48
Freeze Frame:
Voltage: 9.50 V
Count: 141
Speed: 0.0 km/h
Hex Value: 0x12E0
Hex Value: 0x0001
Hex Value: 0x0101
Address 55: Xenon Range Labels: 5M0-907-357-A.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0142
Revision: 00H04000 Serial number:
Coding: 1361094
Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l 0005
Coding: 00000020
Component: AFS-Lst.-Modul r 0005
Coding: 00000020
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 01000000 Serial number: VWZ1Z2K7030219
Coding: 0500040004
Address 62: Door, Rear Left Labels: None
Part No SW: 5N0 959 703 D HW: 5N0 959 703 D
Component: Tuer-SG 007 2102
Coding: 0000144
Shop #: WSC 01530 935 1012552
Address 72: Door, Rear Right Labels: None
Part No SW: 5N0 959 704 D HW: 5N0 959 704 D
Coding: 0000144
End ---------------------------------------------------------------------
Последний раз редактировалось shpuntik; 14.05.2010 в 16:54.
где "46-Central Conv. -- " ?
что кроме ошибки-то беспокоит ?
И ещё:
Coding: 009795
На сколько надо изменить "кодинг", чтобы включить функцию "дотирки" или "вытирания на сухо"?
так же прибавить 2048 и вбить 011843 вместо 009795 ? или в моём случае другое?
Сообщение добавлено в 11:48, предыдущее сообщение было в 11:47
в "46-Central Conv. -- " не входит. в новом Тигуане. (46-й вроде как в 9-й перенесли)
кроме этой ошибки (которая почему-то не сбрасывается) - ничего не беспокоит.
Сообщение добавлено в 14:05, предыдущее сообщение было в 11:48
Ошибку всё же стёр. Лог стал чистый. Обрадовался ...
Дальше пошёл глубже.
1. активировал в радио режим "обучение вождению" и "сервисное меню".
2. поставил галки напротив "DRL switch installed" (байт 9), "DRL via separate lights active" и "Emergency brake warning active".
В итоге появился на приборке жёлтый кружок с перечёркнутой буквой P внутри и полуглуглые штуки вокруг этого кружка.
Что это случилось? Включаю зажигание, завожу, раздаётся пик. Чек не горит, т.е. всё ок, но горит этот оранжевый кружок с перечёркнутой Р внутри.
И появилось куча ошибок при тесте. Причём 2 раза сбрасывал все ошибки - ничего не сбрасывается.
Вернул всё обратно (т.е. убрал поставленные галки и сохранил)
Заново просканировал, очистил ошибки - а они не чистятся....
При скане куда-то пропал Address 02: Auto Trans
Помогите!
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: Malfunction 0010
1 Fault Found:
049409 - No Communication with Transmission Control Module
U0101 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 776 km
Time Indication: 0
Date: 2001.14.15
Time: 14:47:04
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 66.0°C
Temperature: 38.0°C
Absolute Pres.: 990.0 mbar
Voltage: 12.065 V
Cannot be reached
Component: J104 C4 450 V22D 0003
Coding: 0011540
Revision: 00003001
Coding: 0000000002
Revision: BE011001
Coding: 009795
Coding: 03304D
Coding: 000000
Coding: 000000
Coding: 100102
Coding: 0012336
Coding: 0001132
Coding: 110F00
1 Fault Found:
12648704 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 776 km
Date: 2001.14.15
Time: 14:48:34
Coding: 0000002
Coding: 0000005
1 Fault Found:
01315 - Transmission Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 138
Mileage: 776 km
Time Indication: 0
Date: 2001.14.15
Time: 14:48:55
Serial number:
Coding: 000000
Coding: 0004286
Coding: 0000258
Coding: 0004542
Coding: 0023057
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Reset counter: 45
Mileage: 776 km
Time Indication: 0
Date: 2001.14.15
Time: 14:11:23
Freeze Frame:
Voltage: 11.70 V
Count: 75
Speed: 0.0 km/h
Hex Value: 0x1270
Hex Value: 0x0001
Hex Value: 0x0101
Coding: 1361094
Coding: 00000020
Coding: 00000020
Coding: 0500040004
Coding: 0000144
Coding: 0000144
Сообщение добавлено в 15:50, предыдущее сообщение было в 14:05
Сходил часик покурил. Вернулся, подключился, (после вкл зажигания перечёркнутая буква Р в кружочке пропала), зашёл в прогу, сделал скан, потом стёр ошибки. Выкл, вкл зажигание и снова сделал скан. Всё чисто! Ошибок нет! Ух ...
53-Parking Brake -- Status: OK 0000
Coding: 0000328
Coding: 0011540
Revision: 00003001
Coding: 0000000002
Revision: BE011001
Coding: 009795
Coding: 03304D
Coding: 000000
Coding: 000000
Coding: 100102
Coding: 0012336
Coding: 0001132
Coding: 110F00
Coding: 0000002
Coding: 0000005
Serial number:
Coding: 000000
Coding: 0004286
Coding: 0000258
Coding: 0004542
Coding: 0023057
Coding: 1361094
Coding: 00000020
Coding: 00000020
Coding: 0500040004
Coding: 0000144
Coding: 0000144
Уважаемые комрады!
подскажите какой код мастерской указать в 37 и 56 адресе при прописании РНС-510
имею вот такой скан ранее стояла не штатная балалайка сейчас РНС вро все работает но хотелось бы прописать в мозгах правильно
,ВАСЯ Версия: диагност 9.3
Дата версия: 20100222
Шасси: 3C0
Список: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56
VIN: WVWZZZ3CZ8P006425 Пробег: 32360km/20107miles
01- Электроника двигателя -- Статус: OK 0000
03- Электроника тормозной системы -- Статус: содержит неисправности 0010
04- Система контроля положения руля -- Статус: OK 0000
08- Электроника клим. установки / отопителя -- Статус: OK 0000
09- Блок управления бортовой сети -- Статус: OK 0000
15- Подушка безопасности -- Статус: OK 0000
16- Электроника рулевого колеса -- Статус: OK 0000
17- Комбинация приборов -- Статус: OK 0000
19- Диагностический интерфейс шин данных -- Статус: содержит неисправности 0010
25- Иммобилайзер -- Статус: OK 0000
37- Навигационная система -- Статус: Не зарегистрирован 0011
42- Электроника двери водителя -- Статус: OK 0000
44- Усилитель рулевого управления -- Статус: OK 0000
46- Центральный модуль систем комфорта -- Статус: OK 0000
52- Электроника двери переднего пассажира -- Статус: OK 0000
53- Стояночный тормоз -- Статус: OK 0000
56- Магнитола -- Статус: содержит неисправности 0010
Адрес 01: Электроника двигателя Label: Нет ссылки!!
Part No: 06A 906 033 EF
Компонент: SIMOS72 1.6l 2V 1045
Ревизия: --H04--- Серийный номер: VWZCZ000000000
Кодировка: 0004071
Неисправности не найдены.
Готовность: 0000 0000
Адрес 03: Электроника тормозной системы Label: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 C HW: 3C0 614 109 C
Компонент: J104 C4 440 V1 0003
Ревизия: --020--- Серийный номер: 00000775473813
Кодировка: 0004396
1 неисправность:
01309 - Блок управления усилителя руля-J500
008 - нелогичный сигнал
Стоп-кадр:
Статус неисправности: 01101000
Приоритет неисправности: 3
Частота неисправности: 254
Сброс счетчика: 211
Пробег: 26440 km
Отсчет времени: 0
Дата: 2000.00.00
Время: 18:23:11
Стоп-кадр:
Скорость: 0.0 km/h
Hex значение: 0x0000
Напряжение: 12.25 V
Бин.биты: 00011111
Счет: 221
Адрес 08: Электроника клим. установки / отопителя Label: 3C0-907-044.clb
Part No SW: 3C0 907 044 CC HW: 3C0 907 044 CC
Компонент: ClimatronicPQ46 122 0707
Ревизия: 00122021 Серийный номер: 00000000000000
Мастерская #: WSC 00000 000 00000
Адрес 09: Блок управления бортовой сети Label: Не найден
Part No SW: 3C0 937 049 AF HW: 3C0 937 049 AF
Компонент: Bordnetz-SG H52 2002
Ревизия: 00H52000 Серийный номер: 00000004769384
Кодировка: 00848F0700041A00470A00000F000000000D59435C0001
Part No: 3C1 955 419 A
Компонент: Wischer 260407 003 0205
Кодировка: 00046997
Адрес 15: Подушка безопасности Label: 3C0-909-605.clb
Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
Компонент: 0B AIRBAG VW8 032 2522
Ревизия: 12032000 Серийный номер: 003B1P9XMJJD
Кодировка: 0012354
Адрес 16: Электроника рулевого колеса Label: 3C0-953-549-SW20.clb
Part No SW: 3C0 953 549 J HW: 3C0 953 549 J
Компонент: Lenksдulenmodul 006 0010
Ревизия: 00006000 Серийный номер: 3C5953507BB
Кодировка: 0000001
Адрес 17: Комбинация приборов Label: 3C0-920-xxx-17.clb
Part No SW: 3C0 920 852 Q HW: 3C0 920 852 Q
Компонент: KOMBIINSTRUMENT VD1 1216
Ревизия: V0002000 Серийный номер: 00000000000000
Кодировка: 0007105
Мастерская #: WSC 00203 935 95971
Адрес 19: Диагностический интерфейс шин данных Label: 3C0-907-530.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Компонент: J533__Gateway H10 0080
Ревизия: H10 Серийный номер: 1200P075300060
Кодировка: F9801F060002021002
Мастерская #: WSC 00156 935 87548
1 неисправность:
01044 - Неправильно кодирован блок управления
000 - -
Стоп-кадр:
Статус неисправности: 01100000
Приоритет неисправности: 1
Частота неисправности: 3
Сброс счетчика: 69
Пробег: 27805 km
Отсчет времени: 0
Дата: 2000.00.00
Время: 17:13:09
Адрес 25: Иммобилайзер Label: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 AB HW: 3C0 959 433 AB
Компонент: IMMO 043 0383
Ревизия: 00043000 Серийный номер: VWZCZ000000000
Мастерская #: WSC 131071 1023 2097151
Part No: 3C0 905 861 G
Компонент: ELV 027 0380
3C0905861G ELV 027 0380
Адрес 37: Навигационная система (J0506) Label: 1T0-035-680.clb
Part No SW: 1T0 035 680 C HW: 1T0 035 680 B
Компонент: RNS-MID H11 2660
Ревизия: AB001001 Серийный номер: VWZ6Z7J5224008
Кодировка: 000004000000000000
ASAM Dataset: ------------------------- ------
3 Найдены неисправности:
01042 - Блок управления не кодирован
000 - - - Непостоянно
Стоп-кадр:
Статус неисправности: 00100000
Приоритет неисправности: 5
Сброс счетчика: 229
Отсчет времени: 0
01305 - Шина данных информационно-командной системы Infotainment
004 - нет сигнала/связи
Стоп-кадр:
Частота неисправности: 1
Пробег: 0 km
Отсчет времени: 0
00862 - Антенна системы навигации (GPS)-R50/R52
011 - обрыв цепи - Непостоянно
Стоп-кадр:
Сброс счетчика: 230
Пробег: 0 km
Отсчет времени: 0
Адрес 42: Электроника двери водителя Label: 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Компонент: J386 TUER-SG FT 1131
Ревизия: 32008001 Серийный номер: 00000090178522
Кодировка: 0000053
Адрес 44: Усилитель рулевого управления Label: 1Kx-909-14x.clb
Part No: 1K1 909 144 M
Компонент: EPS_ZFLS Kl.069 H08 1901
Адрес 46: Центральный модуль систем комфорта Label: 3C0-959-433-46.clb
Компонент: KSG PQ46 ELV 043 0472
Кодировка: 00910A0801860E763004941570084B0B603CA0
Компонент: Sounder n.mounted
Компонент: NGS n.mounted
Компонент: IRUE n.mounted
Адрес 52: Электроника двери переднего пассажира Label: 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Компонент: J387 TUER-SG BT 1131
Ревизия: 32008001 Серийный номер: 00000538978514
Кодировка: 0000052
Адрес 53: Стояночный тормоз Label: 5N0-907-801.clb
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Компонент: J540 EPB3 VW-09393 0009
Ревизия: 008 Серийный номер: 00000000029763
Кодировка: 0000056
Адрес 56: Магнитола (J0506) Label: 1T0-035-680.clb
Стоп-кадр:
Сброс счетчика: 229
Отсчет времени: 0
Стоп-кадр:
Пробег: 0 km
Отсчет времени: 0
Стоп-кадр:
Сброс счетчика: 230
Пробег: 0 km
Отсчет времени: 0
Конец -------------------------------------------------------------------
Если баян не пинайте. Зарее спасибо спецам за совет . может быть по другим блокам дадите какае либо советы!!!
Посмотреть эти циферки у соседнего любого установленного блока, вбить их в настройки и собственно все.подскажите какой код мастерской указать в 37 и 56 адресе при прописании РНС-510
Coding: 009795
Рейтинг - 1 Спасибо!, 0 Бизнес статус+, 0 Бизнес статус-вал-с Поблагодарил(и) за этот пост
знатоки требуется совет. ситуация следующая--после смены руля на мульти с заменой подрулевого появился следующий периодический глюк(может правда и совпало) при открытии авто брелком(либо при включении зажигания) где-то за щитком приборов судя по звуку начинает щелкать какая-то релюшка упорно, при этом двигатель ключем не запускается, закрытие-открытие авто также не меняет ситуацию, реле продолжает щелкать--спасает сбрасывание клеммы аккумулятора. (ошибки при этом считать было нечем так как не у дома случалось) после подключения аккума релешка умолкает. правда выскакивают следующие ошибки(см. ниже), которые исчезают после буквально 20 метров движения
Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl
Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0667296601
Coding: 0015779
Shop #: WSC 00028 028 00001
1 Fault Found
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
1 Fault Found
000 - -
да еще хочу добавить что прежними владельцами в авто устанавливалась доп сигналка которая была отключена, но не полностью удалена из системы(есть даже пультик тыча на кнопки которого можно было аварийную сигнализацию включить, правда сча видать в нем села батарея-молчит)--может ее останки глючат(правда год до сего момента глюков не было)
В6 2.0TFSI Highline АТ
46 блок - Центральный модуль систем комфорта
Комфортное закрытие стекол при закрытии машины
(не удерживая кнопку закрытия и только для авто оснащенных сигнализацией Plus)
46 блок -> Кодирование - 7 -> Длинное кодирование ->
заходим в 6 байт активируем 1,2,3,6 биты,
заходим в 7 байт активируем 1,4,5,6
и если люк заходим в 8 байт и отмечаем 3,4,5 биты
всё сделал (остались только эти биты - т.е. всё добавил и 5-й бит в 6-ом байте снял...) - но закрывается стекло и люк только после длит. держания кнопки закрытия - что не так?
2.0TFSI, BPY, AT, 2006г.![]()
Всё так. Вы получили возможность закрывать (ставить под охрану) авто с открытыми стеклами при кратковременном нажатии клавиши брелка, закрывать (ставить под охрану) с закрыванием стекол и люка автоматически, то есть не нужно как это было до кодирования удерживать кнопку до полного закрытия всех стекол, достаточно дождаться начаза закрывания. После полного закрывания машина подтвердит закрытие световым (звуковым если активирована данная функция и при наличии штатной сигнализации) сигналом.
Сталкивался с тем, что на некоторых авто могут срабатывать не все двери - зависит от блока двери.
т.е. кратковременно жму на кнопку закрытия - включается сигналка, окна/люк открыты, жму на кнопку закрытия и удерживаю 3-4секунды - закрываются стёкла и люк, но дожидаться закрытия не надо? но в любом случае 3-4 секунды жать надо?
ок, понятно, просто не очень логично как-то работает. было бы и кратковременного нажатия достаточно...
кто-нибудь всё-таки разобрался, как на американце убрать пищалку ремня безопасности или хотя бы её отключить до набора определённой скорости? достала уже!!! если нету варианта грамотного решения - скажите, можно/как её вообще програмно отключить вместе с лампочкой?
и ещё очень актуальный вопрос - можно ли отключить звук предупреждения при открытии водительской двери во время вкл. зажигания или заводки?
Здравствуйте!
Пытался поменять значения межсервисного интервала (км и дни). в 17 блоке ставлю 50 канал как и писалось на данном форуме. Выдает "Не Доступно".
Подскажите! Вроде поиском всё перерыл.
B6 1,8 TSI Tiptronic HL
Как можно отключить ошибку об отсутствии катализатора? лямбду как то можно отключить?
написал тебе в твоей теме
audi TT 2T 211hp (титька бешенная)![]()
