Hello,
sorry I can´t speek Russia, but please is it possible to retrofit it to Passat B6?
Thank you
придется отложить эту идею до замены рейки
Passat B6 HL+2 '07 (BZB, KGV)
Hello,
Thank you
What do you want to retrofit with?
If you want to retrofit with PLA v. 1.0 or 1.5 then your passat should be above 2008 model year. If your passat is older then you need to replace ABS, dashboard and maybe steering assist (but it needs to have channel #04 of adaptation).
If you want to retrofit with PLA v. 2.0 then you need to replace ABS (from passat B7), parking brake unit (from B7), ABS sensors for rear wheels and dashboard (from B7)
and why is working on Octavia II?
http://www.drive2.ru/cars/skoda/octa...52703127/#post
I am sure that I need change steering assist, but octavia II also not have new parking brake, and no ABS from passat B7.
And ABS 3C0 614 109 AG doesn´t support PLA 2?
Jozef is that you? It's me, Dmitry
Octavia has another ABS, from a different manufacture. ABS from octavia (same ABS is installed in Golf, Touran) is made to work without electric parking brake.
I think ABS 3C0614109AG doesn't support PLA 2, but I didn't test it yet. Maybe we will be able to test PLA 2 in my car with Andrey (he was the first one who installed PLA 2 in octavia)
Hello Dmitry, yes I know, thats you)
please but electronic park brake is no problem change to B6, I thing problem will be only in ABS, or engine, because one guy from slovak phorum has retrofit PLA 2 to golf VI but he have Common Rail engine.
And all speek something about byte 18 but I have in ABS coding only normal coding, no long.
or which byte 18? Please try your ABS AG with it)) because my two friend have car repair service and both saw passat B6 with PLA 2. funny is that this guy have pumpe duse and he has not working ACC and he was there for try to start working it
) but PLA 2.0 has working.
jozinecko, forget 2.0 in B6
Just finished 1.5 project in my B6! Would not do that again...And I made both separate B7 center console buttons (for Park Assist and for PDC) fully functional
sure PLA 1.5 is not problem, problem is PLA 2.0, and I cannot understand why is not possible however in Octavia is working as well.
ABS-unit from octavia (golf, touran) has long-coding (18 bytes), and it is possible to encode it to work with special ABS sensors (with letter "A" on the end of the part number). Passat B6 ABS-unit uses short-coding and it is imossible to encode it so it could work with new ABS sensors. ABS from passat B7 works with new ABS sensors.
I will test new ABS-sensors on my car soon.
Dmitry it must work, because also on youtube was one video original from VW and B6 passat has PLA 2.0
also here in Slovakia I heard about two cars which it has, it told me two separated services which has there car for repair something and it as also 6 sensors at back bumper.
вести с полей ))) ездил сегодня к Андрею (N_A)
подключил задний правый датчик от PLA 2, тот который серого цвета и с буквой А в конце номера. И ура, блок АБС от Б6 этот датчик понял и все ок, ошибок нет. Я довольный побежал снимать второй датчик с шкоды Андрея, подключаю его себе и получаю полный ***дец, на приборке столько лампочек одновременно еще никогда не светилось ))), приборка пищит и сообщает о неисправности тормозов, и неисправности двигателя, АБС начинает нервно включать/выключать помпу даже при выключенном зажигании. Ошибок не было только в блоке бортовой сети, дверных блоках и рулевой колонке.
вот скан
но больше всего интересно то, что после подключения двух новых задних датчиков блок АБС стал ругаться на передние датчики, а не на задние. Таким образом получается, что АБС способен работать с новыми датчиками, но вероятно ему нужны все 4 новых датчика.
Теперь думаю где взять 4 новых датчика.
То есть тебе Дмитрий PLA 2 теоретически можно поставить!?
B7 2.0 TSI CCZB DSG6
Если вдруг кого заинтересует
Для обладателей блоков парковочного автопилота версии 1 есть возможность обновления программного обеспечения до последней версии 1.5
Для обладателей блоков парковочного автопилота версии 1.5 есть возможность обновления программного обеспечения до последней версии 1.5
На текущий момент последняя модификация паркпилота версии 1.5 - 1T0 919 475 P
Здравствуйте.
Есть интерес. Сейчас стоит блок 1T0919475H. На сколько я понял, его можно "обновить до 1T0 919 475 P"? Где? Как? Почем?
Перепрошили. По ощущениям стало лучше. Блок стал "P", был "H".
Я тоже шить умею
В6, 1,8 TSI, АКПП
Прочитал тему но так не вкурил потребуются ли какие то изменения в абс при установке версии 2.0 на Б7?
версия АБС
Адрес 03: Электроника тормозной системы Label: 3AA-614-109.clb
Part No SW: 3AA 614 109 AF HW: 3AA 614 109 AF
Компонент: J104 C2 450M V426 0023
Ревизия: --H07--- Серийный номер: 00000004935179
Кодировка: 0131444
Мастерская #: WSC 05311 000 00000
VCID: 71E229DD6881C59677F
И какой сейчас последний блок с версией 2.0?
