В модулях 09, 17, 19 ошибка:
01309 - Power Steering Control Module (J500)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 161043 km
Time Indication: 0
Date: 2010.12.30
Time: 08:28:00
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
OFF
Сам 44 Steering Assist модуль имеет статус "
Cannot be reached 1100", то есть не отвечает...
Дополнительно ошибки в модуле
01 Engine:
5 Faults Found:
001648 - Glow Plug Module 1; Glow Plug Circuit: Electrical Malfunction
P0670 - 007 - Short to Ground
001649 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault
P0671 - 006 - Short to Plus
001650 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
P0672 - 006 - Short to Plus
001651 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
P0673 - 006 - Short to Plus
001652 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
P0674 - 006 - Short to Plus
Freeze Frame:
Fault Status: 01000001
Fault Priority: 1
Fault Frequency: 13
Reset counter: 40
Mileage: 161043 km
Time Indication: 0
Date: 2010.12.30
Time: 08:26:21
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 11.98 V
Bin. Bits: 00110000
Temperature: 2.0°C
Freeze Frame приведены в единственном экземпляре, т.к. для всех ошибок одинаковы.
И в модуле
09 Cent. Elect.:
3 Faults Found:
01117 - Generator Terminal DF Load Signal
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 41
Mileage: 161043 km
Time Indication: 0
Date: 2010.12.30
Time: 11:37:00
Freeze Frame:
ON
Voltage: 12.05 V
ON
ON
OFF
ON
OFF
01049 - Supply Voltage Term 50
006 - Short to Plus
Freeze Frame:
Fault Status: 01100110
Fault Priority: 1
Fault Frequency: 13
Reset counter: 41
Mileage: 161043 km
Time Indication: 0
Date: 2010.12.30
Time: 08:26:00
Freeze Frame:
ON
Voltage: 11.95 V
ON
ON
OFF
ON
OFF
