I don't tried to connect radar with front assist on my car because I haven't it. My radar is E type. I want to know if is possible to be compatible radar with front assist with my car, before buying ACC with front assist.
Passat B6 HL+2 '07 (BZB, KGV)
I've tried to connect M radar to my car (1,8 TSI, automatic gearbox) and Passat 2007 2.0 TDI with DSG and ACC didn't work. Passat 2007 had E radar, and ACC worked with it, but once I replaced it with M radar, it stopped working.
The front assist function in radars J, K, M can be turned off in adaptation. On my car with turned off front assist ACC didn't work.
Во как уже румыны Диму достают по поводу АСС
drsedoy
In this case, I think, ACC with Front Assist is incompatible with Passat 2007 with Manual Transmission (unfortunately)!
BMP with latest firmware. I checked (with ACC type E) engine coding and this type accept ACC, but I received error from engine ECU because I can't code ACC type E for Manual Transmission.
немного субботнего оффтопа
А еще, навесил седня лайн ассист, просто проверить будут ли какие ошибки, работоспособность не проверял
после адаптации рейки под лайн ассист (канал №6) и подключения лампы накаливания габаритного фонаря в качестве нагревательного элемента, все ошибки ушли
в кодировке лайн ассиста указывается наличие адаптивного круиз контроля, но радары первого поколения лайн не видит, поэтому в кодировке указал что адаптивного нет.
потом, временно подключил радар второго поколения, раздел "ассистенты" в меню МФА стал весьма богатым
RKA;PLA v.1.5;MFSW (Scirocco);MFA premium (CC);R-Line tail lights;GPS ant. original;RNS-510 (64Gb);ACC;electrical shade;air vent (B7);RVC (B7);front seats full electric, driver's seat with memory;rear side shades;heated rear seats;foldable wing mirrors with dimming (B7);PTC;DCC;Lane Assist;TV-tuner;Comfort ECU (B7);Gateway (B7);BCM (B7);RDKS;Dynaudio;MDI;180A alternator(B8);Battery regul.;CAWB;Front Assist;R-Line grille;Climatronic (B7);ABS (B7);XDS;City-ANBРейтинг - 1 Спасибо!, 0 Бизнес статус+, 0 Бизнес статус--Boris- Поблагодарил(и) за этот пост
пора добавить в раздел "ассистенты" парковочный ассистент....такого еще ни у кого наверно нет
попробовать бы подключить твой блок и посмотреть что будет, будет ли он корректно работать, и вообще совместим или нет
и еще может быть в пассатовских приборках в меню "ассистенты" нету парковочного ассистента, не предусмотрено в прошивке
Кстати я тут думал-думал и вот что надумал, на фронт ассист блок управления двигателем и коробка наверное напрямую не влияют, все дело в кодировке АБС, а она отличается на одном и том же двигателе для машин с механикой, гидротрансформатором и дсг. Так что влияние коробки есть, но косвенное. Умельцев способных влезть в софт АБС в россии наверное нет, да и за бугром никто не возьмется. Если только пытаться подкорректировать софт блока двигателя, чтобы АБС работал с ним с кодировкой от ДСГ, но опять же таких людей нет.
Менять коробку такой гемор, и дорого блин.
Hi! What happened with your ,,Lane assist,,? Finally work in good condition? Maybe you can show us some pictures!
Hi, I didn't install lane assist because I bought lane assist from Passat B7 to test. New lane assist is doesn't work with my gateway. It needs can-bus extended, but can-bus extended is available only in new gateway (7N0), and with new gateway doesn't work my ACC. I plan to replace windshield and install lane assist in spring.
Some lane assist B7 photo.
с этими 3мя радарами смотрица как космолет
в клубе от 19"![]()
In the next spring you will replace the windshield (with another one with heater for lane assist) and you will use a lane assist for B6 or this ECU for B7?
draganuta, thanks!
Good Luck and congratulations from Spain! I think in my country nobody has complete instalation of ACC. Usually people don't change ABS control unit so...
I hope to see early the new mod working!
Regards,
drsedoy вероятно единственный в мире человек установивший адаптивный круиз контроль))) клуб поднял на мировой уровень![]()
2 года назад я АСС ставил на туарег)))) мог бы и на пассат тада но уже запал после Тура прошел))))![]()
да я собственно после этого и решился его ставить
Но у рестайловых туарегов все проще, АБС менять не надо, просто перекодировать
У Q7 такой же АБС, но там усилитель тормозов надо менять, чтобы был с датчиком положения мембраны, либо просто датчик покупать и подключать к АБС.
У А6 надо приборку менять, тормозная система отличается, но работает и без замены тормозной системы
У А8 тоже приборку менять, про тормозную систему не помню
Да, с Туром проще возиться было, но не все приборки тура АСС поддерживают даже после рестайла.
Вот думаю как бы в Гольф еще его вкорячить)))))))
для гольфов его вроде не существует, зато в гольф можно адаптивную подвеску поставить
)))) наверна... Прецендентов пока не было вроде
