Страница 3 из 24
ПерваяПервая 1 2 3 4 5 6 7 13 ... ПоследняяПоследняя
Показано с 51 по 75 из 589
Тема: Дооснащение пассата адаптивным круиз контролем
  1. #51
    Цитата Сообщение от draganuta Посмотреть сообщение
    Which type of ACC is compatible with Manual Transmission on a Passat 3C 2007 without Front Assist?
    Unfortunately all radars compatiple with manual transmission have front assist. Radars without front assist don't accept coding for manual transmission. I don't know what to advise you for Passat 2007.
    Have you tried to connect radar with front assist to your car?
    Passat B6 HL+2 '07 (BZB, KGV)
  3. #52
    Romania
    I don't tried to connect radar with front assist on my car because I haven't it. My radar is E type. I want to know if is possible to be compatible radar with front assist with my car, before buying ACC with front assist.
  5. #53
    I've tried to connect M radar to my car (1,8 TSI, automatic gearbox) and Passat 2007 2.0 TDI with DSG and ACC didn't work. Passat 2007 had E radar, and ACC worked with it, but once I replaced it with M radar, it stopped working.
    The front assist function in radars J, K, M can be turned off in adaptation. On my car with turned off front assist ACC didn't work.
  7. #54
    М.О. Ногинск
    Во как уже румыны Диму достают по поводу АСС
  9. #55
    Romania
    drsedoy
    In this case, I think, ACC with Front Assist is incompatible with Passat 2007 with Manual Transmission (unfortunately)!
  11. #56
    drsedoy
    what engine do you have?
  13. #57
    Romania
    BMP with latest firmware. I checked (with ACC type E) engine coding and this type accept ACC, but I received error from engine ECU because I can't code ACC type E for Manual Transmission.
  15. #58
    немного субботнего оффтопа
    Супер-адаптивный круиз-контроль
    А еще, навесил седня лайн ассист, просто проверить будут ли какие ошибки, работоспособность не проверял
    после адаптации рейки под лайн ассист (канал №6) и подключения лампы накаливания габаритного фонаря в качестве нагревательного элемента, все ошибки ушли
    в кодировке лайн ассиста указывается наличие адаптивного круиз контроля, но радары первого поколения лайн не видит, поэтому в кодировке указал что адаптивного нет.
ID:	38510 Нажмите на изображение для увеличения
ID:	38507 Нажмите на изображение для увеличения
ID:	38509 Нажмите на изображение для увеличения
    потом, временно подключил радар второго поколения, раздел "ассистенты" в меню МФА стал весьма богатым
    -Boris- Поблагодарил(и) за этот пост
  17. #59
    снова навесил лайн, хотелось проверить его в работе, но увы навесить его в правильном месте не возможно, а правильный угол наклона камеры ваще не известен
ID:	38792 Нажмите на изображение для увеличения
ID:	38789 Нажмите на изображение для увеличения
ID:	38790 Нажмите на изображение для увеличения
    в итоге в действии проверить не удалось, а так хотелось посмотреть как он в пределах полосы держать машину будет
  19. #60
    Мембер Аватар для andreev
    пора добавить в раздел "ассистенты" парковочный ассистент ....такого еще ни у кого наверно нет
  21. #61
    попробовать бы подключить твой блок и посмотреть что будет, будет ли он корректно работать, и вообще совместим или нет
    и еще может быть в пассатовских приборках в меню "ассистенты" нету парковочного ассистента, не предусмотрено в прошивке
    Кстати я тут думал-думал и вот что надумал, на фронт ассист блок управления двигателем и коробка наверное напрямую не влияют, все дело в кодировке АБС, а она отличается на одном и том же двигателе для машин с механикой, гидротрансформатором и дсг. Так что влияние коробки есть, но косвенное. Умельцев способных влезть в софт АБС в россии наверное нет, да и за бугром никто не возьмется. Если только пытаться подкорректировать софт блока двигателя, чтобы АБС работал с ним с кодировкой от ДСГ, но опять же таких людей нет.
    Менять коробку такой гемор, и дорого блин.
  23. #62
    Romania
    Hi! What happened with your ,,Lane assist,,? Finally work in good condition? Maybe you can show us some pictures!
  25. #63
    Hi, I didn't install lane assist because I bought lane assist from Passat B7 to test. New lane assist is doesn't work with my gateway. It needs can-bus extended, but can-bus extended is available only in new gateway (7N0), and with new gateway doesn't work my ACC. I plan to replace windshield and install lane assist in spring.
    Some lane assist B7 photo.
ID:	42730 Нажмите на изображение для увеличения
ID:	42731 Нажмите на изображение для увеличения
ID:	42732 Нажмите на изображение для увеличения
ID:	42733 Нажмите на изображение для увеличения
  27. #64
    Завсегдатай Аватар для demid
    с этими 3мя радарами смотрица как космолет
    в клубе от 19"
  29. #65
    Romania
    In the next spring you will replace the windshield (with another one with heater for lane assist) and you will use a lane assist for B6 or this ECU for B7?
  31. #66
    for B6
    Сообщение добавлено в 23:20, предыдущее сообщение было в 23:18
  33. #67
    Romania
    Good luck!
  35. #68
    draganuta, thanks!
  37. #69
    ESPAÑA
    Good Luck and congratulations from Spain! I think in my country nobody has complete instalation of ACC. Usually people don't change ABS control unit so...
    I hope to see early the new mod working!
    Regards,
  39. #70
    drsedoy вероятно единственный в мире человек установивший адаптивный круиз контроль))) клуб поднял на мировой уровень
  41. #71
    Почетный Мембер Аватар для GRAF007
    Москва, Коломенская
    2 года назад я АСС ставил на туарег)))) мог бы и на пассат тада но уже запал после Тура прошел))))
  43. #72
    да я собственно после этого и решился его ставить
    Но у рестайловых туарегов все проще, АБС менять не надо, просто перекодировать
    У Q7 такой же АБС, но там усилитель тормозов надо менять, чтобы был с датчиком положения мембраны, либо просто датчик покупать и подключать к АБС.
    У А6 надо приборку менять, тормозная система отличается, но работает и без замены тормозной системы
    У А8 тоже приборку менять, про тормозную систему не помню
  45. #73
    Москва, Коломенская
    Да, с Туром проще возиться было, но не все приборки тура АСС поддерживают даже после рестайла.
    Вот думаю как бы в Гольф еще его вкорячить)))))))
  47. #74
    для гольфов его вроде не существует, зато в гольф можно адаптивную подвеску поставить
  49. #75
    Москва, Коломенская
    )))) наверна... Прецендентов пока не было вроде
Страница 3 из 24
  1. Ответов: 575
    Последнее сообщение: 21.11.2021, 18:26
  2. Дооснащение пассата компасом
    от drsedoy в разделе Passat B6
    Ответов: 102
    Последнее сообщение: 21.07.2015, 22:02
  3. Проблемы с круиз-контролем
    от Lawyer83 в разделе Passat B6
    Ответов: 11
    Последнее сообщение: 27.01.2013, 01:09
  4. Ответов: 21
    Последнее сообщение: 03.05.2011, 14:40
  5. Ответов: 23
    Последнее сообщение: 30.12.2010, 19:14
