Address 01 -------------------------------------------------------
Controller: 3B0 907 557
Component: 1,6l R4/2V SIMOS HS D03
Coding: 04001
Shop #: WSC 00000
3 Faults Found:
00282 - Throttle Position Actuator (V60)
17-10 - Control Difference - Intermittent
00537 - Lambda (Oxygen Sensor) Regulation
18-10 - Upper Limit - Intermittent
00533 - Idle Speed Regulation
Readiness: N/A
Address 17 -------------------------------------------------------
Controller: 3B0 919 880
Component: B5-KOMBIINSTR. VDO V09
Coding: 00142
Shop #: WSC 49506
IMMO-IDENTNR: VWZ7Z0V0036570
2 Faults Found:
00771 - Fuel Level Sensor (G)
30-10 - Open or Short to B+ - Intermittent
01176 - Key
07-00 - Signal to Low
и с блока комфорта, хотя к проблеме не относится...
Address 46 -------------------------------------------------------
Controller: 3B0 959 796 K
Component: Zentral-SG Komfort V41
Coding: 04097
Shop #: WSC 05311
8 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
37-00 - Faulty
49-10 - No Communications - Intermittent
00928 - Locking Module for Central Locking: Front Driver Side (F220)
27-10 - Implausible Signal - Intermittent
00943 - Heated Exterior Mirror: Driver Side (Z4)
35-00 - -
00944 - Heated Exterior Mirror: Passenger Side (Z5)
35-00 - -
End -------------------------------------------------------
