Connect your taillights to the electric system of your Car.
Once we have modified the units it's time to put them back in your car.
Each cable has a red and a black wire. The red side is positive(+) and the
black side is the Ground (-).
Connect the red and black wire with the quicklock connectors to the positive
and negative wire of the old taillight wire.
Do the same at both sides of the car.
Connect the new left rearlight to the old wire of the rearlights.
VAG COM MODIFICATION
Go to central electronic Group 9
Set rearfoglights as rearlights function
Find byte 10
Normaly you will see 00000000
Replace this in 00001010
Disable cold diagnose on rearfoglights function
Find byte 18
Normaly you will see 01011101
Replace this in 01010101
If you want four rings of lights you have to modify something more.
Disable brake light as rearlight function
Find byte 09
Normaly you will see 00001010
Replace this in 00000000
Ответить с цитированием
может в Москве где-нить на сервисе какой-нить дядя клепает такие за бабосы??
